right side turn signal
Old Jul 30, 2015 | 09:14 AM
donpaul's Avatar
Default right side turn signal
I have a 2003 Ion the right front signal does not flash. I the socket is new the bulb is new I checked the ground it seems to be ok . Anything else I can look at
Old Jul 30, 2015 | 11:51 AM
goaliemo's Avatar
Its not uncommon for the actual lever to go bad. But I would think that could affect both front and back.
Let me look to see if there is a fuse for the directionals.
EDIT: No fuse. Just the wires going to the fuse box. Interesting how this is most common in 03s and 04s though.
Seems to be people had to adjust the connecting pins for it to work, after replacing the socket and bulb.
Old Jul 30, 2015 | 12:07 PM
donpaul's Avatar
I have bent the tabs in the socket the ground seems to b good
Old Jul 30, 2015 | 12:11 PM
goaliemo's Avatar
You bent the tabs? That could be the problem...
nc_jed
Nov 19, 2009 09:51 PM
ford88mustang
Nov 15, 2009 07:17 AM
murrietafx4
Jan 28, 2008 01:52 PM
flyjetguy
Sep 21, 2007 11:24 PM
busboyblues
Feb 6, 2007 12:01 AM
