No 5 volt reference to ECT
Old Feb 16, 2017 | 08:56 PM
Hissbudd's Avatar
Default No 5 volt reference to ECT
2005 saturn ion no 5 volt reference to cts .help please
Old Feb 16, 2017 | 09:30 PM
tooter1's Avatar
ECT= Engine Coolant Temp?
Old Feb 17, 2017 | 04:58 AM
Hissbudd's Avatar
Default Engine temp sensor
Or coolant temp sensor no 5 volt reference only .45 volts when wire plugged in pcm. Unplugged I probed pcm 9 volts on pcm prong??????
Old Feb 17, 2017 | 05:00 AM
Hissbudd's Avatar
2005 ion sedan 5speed
Old Feb 17, 2017 | 10:06 AM
You have a partial short to ground either through another sensor or a rub through insulation on that circuit. You should never see 9 volts on the 5 volt circuit. You may have a damaged the pcm also. A factory service manual wiring schematic is the way to solve this. Maybe someone over at Saturnfans has seen this, it may be a common problem. There are many sensors that run on 5 volts. Is this the only problem and how did you locate it?
There may be more than one 5 volt driver in your pcm.
pauledgar
Oct 23, 2012 07:05 AM
nitrostreet
Jul 2, 2010 09:41 PM
koolme88
Aug 12, 2008 05:58 PM
hkn royalt
May 6, 2008 10:02 AM
redsl1
Nov 8, 2005 02:13 PM
