(Post 62120)
When you swapped out the ignition switch, did you find a bunch of grease type stuff on the harness connector?
(Post 62120)
That was perennially a problem with the Ion ignitions, among other things.
Usually, it would lead to a bad connection and no crank. I suppose, depending on which pin contacts it is interfering with, it could also cause an intermittent short. Don't know how conductive it is.
(Post 62120)
Did you swap in a new one or a used Saturn ign switch?
Originally Posted by 02 LW300
(Post 62122)
2 amps at 12 volts is not very much load. I would sure like to see a fsm wiring diagram for that circuit. It might just be powering a relay and the relay needs to be replaced.
Ask the dudes over at Saturnfans.com -- there are some diehards over there with fsms to cars they don't even own.
Clearly you know by know I have never seen an Ion. On the road, yes. The mechanicals? Nyet I did read something about an internal relay that can get fubar'd. Let me see if I can dig it out of my browser history.... |
| All times are GMT -5. The time now is 09:55 AM. |
