Inner tie rod boot clamps
I recently replaced the inner and outer tie rod ends on an 07 Saturn Ion-2 2.2. The outer part of the boot that holds onto the rod had a small pinch style ring clip but the inner end of the boot where the bigger diameter is has a one time use clamp that breaks or needs to be cut loose. The new tie rod ends didn't come with new boots or clamps, and I didn't have any zip ties, so I just installed the boots without them. They fit pretty snug, but is this OK, or should I try to find some clamps? It's been said that they're hard to find. Are zip ties or anything really necessary?
Thanks
Thanks
