im going to cry
Old Jan 8, 2014 | 06:41 PM
mandee_07's Avatar
Default im going to cry
I have a check engine light on in my car
Onstar ran a diagnostic and says my my emissions system isn't running correctly. Says if the light doesnt go off within 7 trips I need to take it in within 7 days.
Where the hell do I start? I dont have money for this right now ugh!!! I wanna cry.
Old Jan 8, 2014 | 09:56 PM
Did you get some gas today, Mandee? If so, it may be as simple as a loose gas cap. Don't freak out yet. Even if it's not a loose gas cap, it could be the gasket around it not sealing properly. You can get a new gas cap, but I'd recommend trying one from a GM dealership before trying the aftermarket junk that's out there. But, that's ONLY if you need one. Tighten that gas cap until it clicks. Then it may take a few drive cycles for the code to clear itself.
Old Jan 8, 2014 | 10:44 PM
mandee_07's Avatar
Havent gotten gas since sunday. Should I go by advance auto and get the code?
Old Jan 8, 2014 | 11:06 PM
yes. Post the entire code Pxxx where x are numbers. We'll try to help you sort it out, And screw the 7 day limit --- last I checked onstar techs were not trained in interpreting check engine light.
Get the codes read before doing anything else anf post here. Remember the Pxxx not the description the Autozone lackey gives you.
Old Jan 9, 2014 | 07:00 AM
mandee_07's Avatar
Ok I'll go by there at lunch or after work today.
Old Jan 9, 2014 | 07:47 AM
I agree with derf about the codes. And just for s*^%s and giggles, check your gas cap anyway.
Old Jan 9, 2014 | 10:55 AM
mandee_07's Avatar
I have a gas cap message if its not right...but ill do it anyways just for you
Old Jan 9, 2014 | 11:32 AM
mandee_07's Avatar
P0446
Thats the code
Old Jan 9, 2014 | 01:48 PM
Check the hose going to your EVAP canister and make sure it hasn't come off or maybe gotten crimped somehow, Mandee. It may be that simple.
Old Jan 9, 2014 | 01:57 PM
mandee_07's Avatar
Where is that located? lol I can check it if you give me a location. Pretty handy like that...just havent learned locations of everything.
