Cylinder 2 Misfire
Old Oct 31, 2013 | 03:29 PM
amn0025's Avatar
Default Cylinder 2 Misfire
My check engine light came on recently after going on and off for a few weeks. My saturn then started hard shifting and was noticeably pulling. I have a 2007 Saturn Ion 2 sedan with about 98k miles.
I took it to O'Reilly's and the code came back as a cylinder 2 misfire (p0302). I replaced the spark plugs (kept at manufacturer gaping) and the coil for cylinder 2. That fixed the problem for about a week and then the check engine light came on again and the hard shifting come back.
I read on here that it might be dirty fuel injectors, so I put some Chevron Techron in my tank and have driven about 80 miles with no noticeable difference. I hate to take it to the shop if I can fix it myself. Any ideas as to what it could be?
Old Oct 31, 2013 | 04:02 PM
I'm not familiar with the Ion at all. I know on the S series Saturns that a faulty ECTS or connector can cause all kinds of problems, though. Maybe that?
Old Oct 31, 2013 | 06:08 PM
Damn near looks like a copy and paste from another site I read. If you know the spark plug is good. If you know the coil pack is good. It's likely in need of a new fuel injector, not fuel injector cleaner you pour in the gas tank.
What does noticeably pulling mean?
Old Oct 31, 2013 | 06:15 PM
PS: Ms. amn0025
Stop in the new member area and give yourself a proper introdution. When done go to the USER CP top left of the page and add your first name, location, and car info to your "signature".
Old Oct 31, 2013 | 06:39 PM
amn0025's Avatar
I mean that it has a lag when accelerating and noticeably lacks power for a few seconds.
Hmmm, how difficult is that to replace?
Old Oct 31, 2013 | 06:45 PM
Not hard at all. Don't go to Al's Apple Orchard and Auto Parts for the injector. Get it from the dealer you'll not be sorry. Use top tier gasoline look it up if need be.
Why is your IP address a new one each time you sign on? 3 count so far, all differant servers, dynamic, static etc.
Old Oct 31, 2013 | 06:55 PM
amn0025's Avatar
I suppose my IP address is different because I switched computers since I moved from work to home.
Could you point me to a good video or guide to changing these out?
Old Oct 31, 2013 | 06:58 PM
Search you tube or the internet. Might be something, good luck Girl. Good job on the signature.
Old Oct 31, 2013 | 07:01 PM
amn0025's Avatar
I'm on it! For some reason there's never much about '07 models.
Old Oct 31, 2013 | 07:08 PM
06 is 100% the same....and other years are close enough to give you an idea.
