Buy new or repair
Well we are at a crossroads. I really do not have the money to put on a new car but I'm wondering if I'd be throwing money into the wind repairing. My '03 Ion has been a perfect little car (excluding all of the times it wouldn't start because of the key situation) The only thing that needed to be replaced was a battery, tires, and a new gas cap. But now it needs new tires again (understandable) and I'm not sure why it: 1. Idles rough, may need engine mounts? Engine pulley and/or belt? or elect fan? 2 Ft end Clunks! may need shocks/struts or control arm bushings? 3. rear brakes squeal, they are in good condition but may need drums turned and ceramic pads?
Has anyone had any of these problems? Are they worth fixing?
Thanks in advance!
Thanks in advance!
Mechanics say nothing is wrong but my 03 Ion idles like a truck. I'm thinking it could be engine mounts, belts and pulleys or the electric fan. Unpluging the fan fuse seemed to help some but did not take away all of the noise/vibration. Anyone else have experience with this?
Anyone have experience with super loud squeaky rear brakes? This just happens after sitting for a while and does not need new pads but I'm thinking ceramic shoes and newly trued drums would help.
how many miles?
Which tranny in car (CVT, Auto, Manual)
1) Clean throttle body (when was it last done), run some techron fuel system treatment.
2) Pretty sure clunk may b sway bar bushings but don't quote me
3) I hate drum brakes. Usually you turn the drums if they get out of round, though I suppose it could be a resonance
Thanks in advance!
Thanks in advance!
2. Front end clunks can be a couple of things. Tie rod ends, wheel bearings, c/v joints all clunk. Turn the wheel to the outside and take a look. Look for any torn rubber boots, that's a good give away. Lift the wheel up, chock the opposite back tire. See if there is any play in the noisy wheel by rocking it up and down and left and right. If there is a little play, then it's a wheel bearing. If the strut cylinders are leaking, then it's time for new struts.
3. Brakes all wear out eventually. Drum hats can be machined and pads easily replaced. Squeal might be solved by just an adjustment.
Sometimes a visual inspection can narrow down the culprit better than just guessing form a noise. Watch some videos like Eric the Car Guy on YouTube to get some basic info on what to look for.
Also spending a couple hundred bucks in repairs on a reliable car is better than spending several thousand on a car with unknown problems that you'd have to throw more money at to fix them.
Good luck with your diagnosis and your decision!
Sorry, I deliberately wanted to separate the questions because most people only answer 1 question. Wont happen again.
Dave has given you some very sound and solid advice. But I like Techron over the Seafoam. I've always had good luck with it and it's less expensive. I'm a cheap bastard and have to squeeze every penny I get my hands on. I hate living it Florida. It's too expensive.
thanks
