Broken vent tube from gas tank
Old Nov 27, 2021 | 10:17 PM
Buckeye_Guy's Avatar
Question Broken vent tube from gas tank
2007 Saturn Ion 3
I dropped the gas
tank. The inline quick-disconnect fitting for the vent tube broke when I squeezed on the clips. It still wouldn’t come off, so I had to end up cutting the hose. See pic.
What’s the best way to fix this? The fitting is broken, so even if I figure out a way to fix the cut section, it still wouldn’t work. Should I just not use a fitting, and run some kind of hose from the cut section to the tube that runs up to the filler? Or can I buy these hoses?
Thanks
Old Nov 28, 2021 | 09:47 AM
lrbraner's Avatar
Dorman has a complete line of repair fittings and connectors for plastic fuel lines. Go to their website.
Rubber fuel line may be a feasible fix.
Old Nov 28, 2021 | 10:59 AM
Will check out Dorman. Thanks!
Old Nov 28, 2021 | 01:17 PM
Use the same material as your fuel lines. Do not use plain old rubber hose. It will not stand up to fuel and you don't want whatever dissolves on the inside going into your injectors.
Check out YouTube videos for repairing fuel lines before you try. It is not that difficult but there are certain things you must do to ensure a long-lasting non leaking fit.
Old Nov 28, 2021 | 01:25 PM
lrbraner's Avatar
It is a vent tube. And I said fuel line hose, not " plain old rubber hose"
Old Nov 28, 2021 | 03:17 PM
Dude ,
What's with the spit back?
You're exactly right. You said what you said. And I said what I said. The two do not intersect. They weren't meant to.
Why would I bash your response?
You do nothing but contribute meaningful support on this site -- which I appreciate..
I was indeed referring to plain old rubber hose.
Most people who don't work with fuel systems don't know not to do it. I did not say do not use rubber fuel line.
Enjoy the rest of your weekend
Derf
Doug Shinnan
Feb 5, 2021 11:55 PM
Perry Rose
Dec 5, 2020 09:21 AM
jaf
Jun 26, 2018 11:49 PM
drackett
Jan 2, 2010 07:18 PM
arfalberg
Jan 13, 2006 01:34 PM
