Audio Questions
Old Aug 10, 2009 | 12:45 AM
Saturntuner88's Avatar
Default Audio Questions
When I bought my ION the Parts Manager that used to work at the dealership which is one of my good friends told me that i couldnt install an after market radio because it would set off a check engine light. Is this bull**** or is it true and if it is true how do i get it so it doesnt set off the light because i see that 85% of the people with the same car have an after market radio
Old Aug 10, 2009 | 01:39 AM
Well - as I understand it, the check engine light says (in effect) that there is a failure code of some type set in the computer. I've researched my listings carefully, and nowhere do I find a failure signal that says ..."after market radio installed".
Old Aug 10, 2009 | 07:19 PM
but will it set off the check engine light and will it mess with any thing else some one at a stereo shop today told me theres a special harness needs to be ordered and it costs $120.00 because the door chimes and a few other things i linked into the wireing harness of the radio
Old Aug 10, 2009 | 07:42 PM
Well, I agree that the original radio has a connection back to the CHIME fuse (org wire) which is hot at all times, but unless you simply butcher the connectors, that should not create a problem.....
Old Aug 14, 2009 | 11:55 PM
cool thanks for the help now i can actually put in a radio and get rid of the stock radio and get something decent in it
StRN0812
Jul 30, 2008 11:08 AM
gtkillerwannabe
Jul 17, 2008 08:36 PM
93sl1
Mar 6, 2008 10:09 PM
MazDanRX795
Dec 18, 2007 08:24 PM
qkslvrrx8
Jul 17, 2006 08:13 AM
