2006 Ion steering column wiring-no crank no start
https://cimg9.ibsrv.net/gimg/www.sat...79c2bf2c04.jpgThe green plug that is not plugged in. I could not see a place to plug it in?
https://cimg0.ibsrv.net/gimg/www.sat...519b0edcfa.jpg https://cimg8.ibsrv.net/gimg/www.sat...c097fa7283.jpg https://cimg5.ibsrv.net/gimg/www.sat...acb9f5a3d3.jpgThis panel was removed, do not know why. https://cimg0.ibsrv.net/gimg/www.sat...403d77f37f.jpgThe yellow connector was disconnected. I didn't see any damage and plugged it back it. Someone tried to steal my car and now it won't start. I turn the key and nothing. No crank, no bells, and no dashlights or radio.<br /><br />They ripped off the steering column shroud and had one of the wiring harnesses unplugged on top of the column. SEE PHOTOS<br /><br />Found where to plug in one but don't see where to plug in the GREEN one? |
no photos attached.
Go to edit post, go Advanced (at the bottom) and use the little picture frame icon in the upper toolbar to bring up the insert image dialogue. Sounds like they were trying to bypass the PASSLOCK II system bt swapping out your ign switch for one of 12 resistors. Or they were morons and didn't realize it had a theft deterrent system in it |
Thanks for the upload instructions
Originally Posted by Emsafeman
(Post 58861)
I believe it should connect on the back of the ignition switch, opposite the key
Bingo! The green plug does goto the ignition switch. Thankfully my car runs just fine. You made my day, thanks for your help!
Another Satty back out on the road.......
And now I’ve seen the insides on an ION steering column lol... never had mine apart... |
Then how did you acquire it from that parking lot in Texas?
