2004 Ion Transmission
Old Oct 15, 2015 | 06:01 PM
iontroubl3's Avatar
Default 2004 Ion Transmission
My 2004 Ion (V4, 94000 mi) had its transmission go out. Evidently, a new one is $4500.
Is it worth replacing? Can I get a different transmission to work in it? Should I get a used one off Craigslist? Are there any other issues that I should know?
Thanks.
Old Oct 15, 2015 | 09:07 PM
19bonestock88's Avatar
I'm guessing it has the VTi transmission, a CVT, right?
I would not buy a used VTi transmission, especially from craigslist... If yours is dead at 94k miles, how long would another used one last? The best direct replacement option is a new VTi trans, which would likely cost more than the value of the car, assuming its in mint condition otherwise... You still have options though...
1.
Can you drive a stick? There are lots of Getrag F23 transmissions in circulation, and lots of wrecked IONs could source a transmission, clutch, and all the electronics/linkages you could need for the conversion from auto to manual...
2.
Some 04-05 IONs were equipped with another type of automatic transmission, the Aisin AF23, which is a traditional type, five speed automatic transmission, and much more durable an the VTi that you already have... There is a sticky on this site that contains all the information you need to make the swap happen, if you so desire, and there is a link to the thread to save you the trouble of looking at the top of the page...
https://www.saturnforum.com/forum/sa...ion-swap-6484/
3.
All of the 06-07 IONs were equipped with the corporate GM-made 4T45 transmission, which is a four-speed unit, used across many platforms... I would imagine a swap could be made to happen, but I'm not sure how to get it done... Some research would be in order... I imagine electronics from an 06-07 car would be a start...
Old Oct 18, 2015 | 09:33 PM
goaliemo's Avatar
I have 2 automatics (af23 and 4t45e) and 1 F23.
All have around 150k give or take on em.
$300 for any of them. If youd want the manual id include everything needed for the swap for $400
I am in Southern Louisiana.
kvss.ravi
Mar 30, 2012 06:49 PM
wapayne
Sep 6, 2011 04:08 PM
silverion3
Jan 17, 2011 07:15 AM
Gateway
Apr 16, 2009 08:19 AM
