2004 Ion 2 Quad Coupe knocking noise
Old Aug 16, 2017 | 08:22 AM
Jpeterson's Avatar
Default 2004 Ion 2 Quad Coupe knocking noise
I have a 2004 ion2 coupe with the 2.2L Ecoteck. Just this morning it started a knocking noise, best I can tell, in the front. It only does it between 15 and 25 MPH. And only when my foot is off the gas. Goes away as soon as I press on the gas or when I slow down below 15 MPH any ideas? Thanks
Old Aug 16, 2017 | 09:15 AM
First check for a loose wheel! Then I would run it in the air. Jacked up, rear wheels chocked, very secure or take it to a shop. May be an axle or a warped rotor making the caliper thump.
Old Aug 17, 2017 | 02:13 AM
These cars seem prone to sway bar bushing end link failure.
Check thoise.
Old Aug 17, 2017 | 12:06 PM
19bonestock88's Avatar
Check the upper strut mounts, the sway bar bushings, the end links... An oily coating on the strut body means it's broken and leaking its fluid...
tooter1
Jan 21, 2017 03:52 PM
oleg_8831
Apr 22, 2016 02:06 AM
05Ion3Quad
Feb 18, 2016 10:04 PM
Digit4lPyro
Feb 27, 2010 07:56 PM
Kenmtb
Nov 18, 2006 08:48 AM
