What were you referring to, goalie? The connector or the drop coils? I'll text you my address anyway...
But I figured that since you and derf were moderators, you could view info on the other users(like our birthday we have to put in to join)
So, I think I have successfully rigged my clutch... I had a round piece of rubber about a quarter inch thick (and about an inch and a quarter in diameter) that I jammed in the bracket that the clutch pedal swings up into, preventing the excessive uptravel of the clutch... I might thin it a little and allow a little bit of play in an effort to keep it from constantly applying pressure to the clutch pedal...
Well, I meant,"finish this phase"... After doing the OBD port and the CASE learn, I'm gonna tackle this low vacuum/crappy idle issue... I sprayed the crap outta the lower intake, and around the supercharger gasket and around the TB gasket, and it didn't idle up or anything... I used a whole 5oz can trying to find a leak, and found nothing... Even cleaned the TB thinking that something wasn't letting it close completely, but no such luck...
Hey, I'll still make good on that free soldering iron. and I will throw in some heat shrink of different sizes cause I don't know which one you need and I have at least 6 feet of each one I could find at an electronics store.
No crimpin'
No crimpin'
Actually I have the heat shrink lying around here somewhere... I've done lots of audio installs, some professionally, but I've never soldered a wire(yes I disclosed that to any client)... I used a complex twist, then wrapped with electrical tape, then followed up with heat shrink...
And the injector o-rings can cause vacuum loss? Any way to test them? Or just replace and hope for the best... At this rate, I'm about to do another compression test on #4 to see if it's gotten much worse... It still does crank over evenly though...
