-   -   19bonestock88’s 2004 ION-2 sedan “Green Line” BUILD (https://www.saturnforum.com/forum/saturn-ion-22/19bonestock88%92s-2004-ion-2-sedan-%93green-line%94-build-11436/)
02 LW300 Dec 23, 2018 11:55 PM
Your front fender matches as good as my rear bumper! Those skirts are cool.
19bonestock88 Dec 24, 2018 01:59 PM
I can make you a set if you want lol
derf Dec 25, 2018 10:33 AM
Just say no.
19bonestock88 Dec 27, 2018 02:10 PM
While I’m not particular about appearances and used coroplast due to it being cheap and easy to work, I’d love to make a set from Celtek, which is a PVC foam board available in thicknesses similar to coroplast, and at a similar weight. It produces a more finished look and is also easier to paint than is polypropylene...
19bonestock88 Feb 24, 2019 07:33 AM
It’s been a while since I updated my thread, but the car still exists (I swear)...
i got new tires installed (Hankook Kinergy ST 205/65-15) and changed my oil, and I’ve noted a noise coming from the front end that’s distinctly sounding like wheel bearings, so I’m saving money up for that... I have noticed greater rolling resistance so no doubt mileage is down, not that I’ve been tracking it too closely lately...
i also got back into ridesharing due to missing the side income, so I’ve also been working the car much harder lately...
DropDead Apr 17, 2019 02:28 AM
Interesting. Haven't seen this done to an ion yet. Look into splitters as well for the front. Can get some cheap universal ones on eBay or wish.
Also, I've had luck with the ebay wheel bearings. 40 or 50 for both with abs
19bonestock88 Apr 18, 2019 09:49 PM
Awww man, I once again forgot to update my build thread... I ended up losing a wheel skirt from driving too fast so I took the other one off until I can remake the mounts...
I also did new Moog wheel bearing/hub assemblies with new Stoptech brake pads and a set of drag reduction clips...
car will consistently pull 42-45mpg highway measured at the pump as it sits but I need to redo some things and... check my tire pressure? It’s been a while so I don’t doubt they’ve leaked some but they *should* be at 55psi...
19bonestock88 May 9, 2019 01:15 PM
I got a new steering wheel from a salvage yard. It’s a leather wrapped wheel from an 06 Lv3 car, but will need some cleaning... it has the cruise buttons but I’m not hooking them up bc my car doesn’t have cruise...
19bonestock88 May 21, 2019 11:02 AM
Got the steering wheel swapped over (details in Detailing sub-forum), but the other night I hit a raccoon going 70mph, with no damage on the outside of the car, but it did wreck my fender liner and radiator duct... I bet I used almost a dozen zip ties stitching the panels back together and reattaching them...
people made fun of me when I did the lawn edging air dam but it scrapes dozens of times a day in ridesharing use and it took a hit from a raccoon at 70mph and it’s still there...
derf May 21, 2019 09:43 PM
You should mount a camera so you can share vids of all the stuff that dives in front of and into the side of your ride.
I didn't realize I forgot to make fun of you for the lawn edging. I'll get right on that.
