Saturn Aura 2009 Replacement Key
I have no keys for a 2009 Saturn Aura.
Will I need to have it towed to the dealership or can they cut a key based on VIN? Also what would the cost look like. |
Yes, it will have to be towed to a GM dealership. You will also need to bring proof of ownership. It needs to be cut and programmed to the car.
Cost depends on the key price and labor rate of the dealer. I recently paid 200 for a key to be cut for an 06 dodge grand caravan. That was key/labor/tax out the door. |
Originally Posted by DropDead
(Post 68160)
You might be able to with a higher end scan tool. But I'm not 100% sure on that. I've read that some snap on scanner and equivalent can. But I can not confirm
(Post 68163)
Worth a shot. I believe the pontiac g6 was on the same platform. Can look at those too
Maybe a reference to the passlock relearn ?
(Post 68166)
I appreciate you checking back in. I really thought it would have to be programmed via bcm/ecm for the security stuff.
Learned something new |
