Rear View Mirror
Old Mar 21, 2025 | 09:58 PM
AuraXE's Avatar
Default Rear View Mirror
My rearview mirror (2007 Saturn Aura XE) is not powering on. I don't know if the mirror I got to replace a cracked and discolored one is the correct one. I have a diagnostic procedure for the 2007 Saturn XR mirrors, but I don't believe that it is applicable to my 2007 Saturn XE. The Circuit/System Testing sheet mentions using terminal 9, but the connector I have does not have a wire connected to terminal 9.
My connector has the following pins connected:
8 - black wire (ground)
11 - dark blue (keypad signal)
12 - black and white (keypad supply voltage)
14 - gray (keypad green LED signal)
15 - brown and white (keypad red LED signal)
Can any forum member help me with this issue?
Old Mar 23, 2025 | 09:26 PM
grcauto8453's Avatar
You replaced the mirror and it has never powered on?
Old Mar 23, 2025 | 10:22 PM
AuraXE's Avatar
That is correct.
Old Mar 24, 2025 | 07:10 AM
Brand and part # of replacement part?
Which OEM original part number?
XE what engine?
The connector which you are describing is on the pigtail attached to the car, correct?
Old Mar 24, 2025 | 09:09 AM
Originally Posted by AuraXE
That is correct.
I would think you have the wrong or defective mirror as a replacement. Why not get the correct mirror rather than rewiring this one?
Old Mar 24, 2025 | 10:56 AM
AuraXE's Avatar
What has been my problem is determining what the correct mirror is. I no longer have the old mirror and, therefore, I do not know what the part number is. The one I have was taken from a 2007 Saturn Aura XE (same as the car that I own), so I thought it would be OK. I need to figure out how to obtain the correct information (i.e., either service information or part number).
Old Mar 24, 2025 | 07:42 PM
https://charm.li/
Old Mar 24, 2025 | 08:42 PM
There are three different mirrors for your car.
onstar with auto dimming headlights
onstar without auto dimming headlights
xr without telematics.
what is your zip and options?
Old Mar 24, 2025 | 09:43 PM
AuraXE's Avatar
My zip code is 41018. I bought the car used, so I cannot tell you exactly which options it has. My car is an Aura XE. It does not have auto dimming headlights. I believe the original mirror (I discarded it because it was cracked discolored) had an OnStar button on it.
Old Mar 24, 2025 | 10:18 PM
http://www.carthageautoparts.com/
I would call these guys. Reasonable prices, close to you. Tell them you found them on Car-part.com. They pay to advertise their inventory.
They have eight listed for about $26 each. I bet you can find one there that will work in your car. They can run your VIN to see which one you need.
Andy
