ECM Swap
I have two Saturn Astras. One runs with a bad motor. The other one does not run because the key wouldnt turn and the part that connects the ignition to the CIM broke. So it's an immobilizer issue now. So, my options were to swap motors to the black car or swap everything that relates to the immobilizer to the blue car ( this was my thought anyway). i opted to swap all the parts that I thought would trigger the immobilizer to the blue car. In my mind, if i swapped the ECM, the ignition cylinder and housing, the CIM/clockspring that even though i would have to get the other parts programmed to it. at leat it would start and i could drive it to the dealership which is really far away from where i live (farther than is reasonably feasible for me to pay a tow truck to take there) But, lo and behold, that didn't work. So now im thinking maybe i need to change out the cluster as well and possibly the infotainment display in the center? Will that make the car happy? What am i missing? There were also wires that connected the CIM to somewhere under the hood that i thought maybe i needed to also swap. And just for information, all these parts i have replaced have all come from my other astra which was starting and running right before I swapped them. Is this a good solution to this problem or should i have just done the motor swap to the other car?
I know nothing about an Astra but you are dealing with security issues and a security relearn is most likely the only solution. Charm.il may have the security relearn procedure you need. You may need to change other modules to make it work.
And yes the engine swap would have been much easier.
Hopefully the security relearn Will get you up and running.
I would have suggest that you join an Astra only forum. The amount of knowledge there is far superior to that on our forum.
Trying to help you, not get rid of you.
Please stop back and let us know if you get it solved.
Where might I find an Astra only forum?
https://www.astraownersnetwork.co.uk/forums/astra-h.10/
https://www.vauxhallownersnetwork.co...-cars-area.83/
Since the Astra is very similar to the opel astra and is offered in Europe by GM as a Vauxhall, both of these forums are hosted in the uk.
I'm sure there are more. Folks please chime in if you know of others specifically for the Astra.
"The Bev" 😁
Thanks so much for the support and advice! Hope this helps someone in the future!
∞ Saturn Forever ∞
𖹭 🪐 𖹭
