Astra - yellow headlight cleaning
Old Jul 23, 2025 | 08:27 AM
AstraFasta2's Avatar
Default Astra - yellow headlight cleaning
Easiest 5-minute fix to yellowing headlights we found was:
- Wash and rinse headlights
- Meguiar's Ultimate Polish" using a microfibre towel.
- Apply some wax or other protection
Note that above products may not be appropriate for the polycarbonate lenses so read the label. We had no issues but you might.
We have tried several popular retail UV restore kits (basically sandpaper, polish, protectant). They took a lot of time and work. Not sure if the "Meguiar's Ultmate Polish" trick would work if one had not previously sanded the headlights (we sanded them years ago but not for this 5 minute test)..
None of the headlight "restore" products or tricks lasted us more than say 6 months (car parked inside or facing south might have better success)..
We read about pelople using other "tricks" like WD-40 or toothpaste. None of these "tricks" worked on the Astra. Maybe they are great for headlight cover plastics/coatings on different car models.
Old Jul 23, 2025 | 10:06 AM
I used Maguire's Plastix (same product?) on the headlights for my 97 SC2. I did not wax them afterwards, as it appears I am a moron in this respect. I did not sand prior to application. The outcome was awesome, but without protecting it, it would again become yellowed in about one year..
Old Jul 23, 2025 | 08:37 PM
The protectants we tried just didn't seem to last very long.
Maybe a 2K clear (dangerous to breath in) or some other pro application would be more durable.
Old Jul 24, 2025 | 08:40 AM
Not quite fix it in a can, because it's more expensive, but the same concept.
Polishing away the outer oxidation layer away doesn't stop whatever layer you get to from then oxidizing due to the UV of the sun and other factors.
The true cure probably eats away the lining of your lungs and causes permanent neurological damage. This would leave you unable to breathe and likely unable to drive. Clearly a lose-lose
Old Jul 24, 2025 | 08:44 AM
I have used baking soda on a damp cloth. It's okay for a temporary fix, but nothing that I've tried from the auto parts stores has lasted longer than 6 months. Sometimes I miss the days of glass headlights.
Fire_Wolf_33
Apr 19, 2025 07:43 AM
jjmontgomery
May 28, 2024 05:00 PM
19bonestock88
Jun 6, 2014 01:05 PM
jcrouch75
Jul 14, 2012 09:37 PM
saturnbadgirl
Mar 21, 2009 06:51 PM
