State Inspection Trouble
Old Jul 31, 2009 | 04:16 PM
SaturnManDan's Avatar
Default State Inspection Trouble
For those of you that are having trouble getting your SC1 to pass emissions inspection because the computer wont reset "CHANGE THE ETCS or ECTS SENSOR..it will save you many hours and many dollars. I went through disconnecting the battery, pulling the PCM fuse, Complicated driving cycles, cleaning of wiring and connectors, voltage testing and even some colorfull language only to fail the state inspection over and over..I changes the ECTS sensor, did one driving cycle and it passed with flying colors.
I want to thank everyone that has posted their stories and opinions on the matter so that I would not cleaned out by some mechanic replacing all the parts the computer was saying was bad..
I would change the ECTS sensor on a car without showing signs of trouble to head these problems off before it becomes a nightmare..
This is the best set of instructions on how to reset the computer !!
OBD-II Driving Cycle
If you have a 96 or newer vehicle (
http://www.saturnfans.com/forums/showthread.php?t=122994&highlight=drive+cycle#) you have the OBD-II diagnostic system. This system is constantly monitoring the sensors and solenoids on the engine. If you have replaced the battery, disconnected the battery or cleared the codes after making a repair you will need to do what is called a "Driving Cycle". This will perform a diagnostic on all the systems the computer monitors. This cycle can be done in under fifteen minutes.
To perform an OBDII Driving cycle do the following:
1. Cold Start
In order to be classified as a cold start the engine coolant temperature must be below 50ºC (122ºF) and within 6ºC (11ºF) of the ambient air temperature at startup. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.
2. Idle
The engine must be run for two and a half minutes with the
air conditioner on maximum and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.
3. Accelerate
Turn off the air conditioner and all the other loads and apply half throttle until 88km/hr (55mph) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
4. Hold Steady Speed
Hold a steady speed of 88km/hr (55mph) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
5. Decelerate
Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 32km/hr (20 mph). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
6. Accelerate
Accelerate at 3/4 throttle until 88-96 km/hr (55-60mph). This will perform the same diagnostics as in step 3.
7. Hold Steady Speed
Hold a steady speed of 88km/hr (55mph) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the
battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
8. Decelerate
This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
DCARNEY51
Jun 18, 2015 02:43 PM
firemedic2572
May 22, 2015 09:11 AM
DailyPlanet
Aug 23, 2014 01:06 PM
Saxon
Aug 2, 2011 10:13 AM
one day
Jan 20, 2006 02:58 AM
