SC1 won't turn over
I have a 2001 SC1 - automatic. It has a few problems :P
When I turn the key I get nothing... no sound... no turning over. All the lights on the dash do what they would normally do during start-up. They come on, than when the key is full forward they all go off (including headlights) except battery and oil. I'm pretty sure i here my fuel pump kick in too. We think it might be the starter switch, but we don't know.
Also, whenever it shifts, there is a loud clunk and it rattles the car a bit. This happens when switching to drive of reverse as well as when it shifts gears while driving. I have replaced a motor mount already and can't seem to find if there is a forward transverse mount.
any ideas?
any ideas?
Also, yes we considered the neutral safety switch. That's interesting that they got recalled. I will check it out. thank you
. Just to add, it does start sometimes just randomly. No problem at all, as if it were brand new. Than if you go to do it again it will just click. It seems that it won't start whenever the car is warm (either from running or from the hot sun?). This is what confused me most.
The same thing happened to my 98 SC2. I checked everything.. battery, connections, starter, alternator... nothing!!
I had a diagnostic done on the whole electrical system and apparently i have an after market alarm on the car that i didn't know about. So i uninstalled it and its started up fine ever since. It could be something like that because you are getting power if not then it is the starter.
