SC1 or SC2?
Old Jun 9, 2015 | 09:07 AM
RaceyRaider3's Avatar
Default SC1 or SC2?
So without running the VIN, how do I know if my car is a SC1 or SC2? Serious question...
Old Jun 9, 2015 | 10:02 AM
Just look up a picture on the web. It's very obvious. And unless your cars engine has been replaced, the SC1 refers to the SOHC and SC2 was DOHC. You show that you have an SC2, so I'm guessing you have the DOHC. Post a pic and we can tell you. The DOHC is clearly marked on the valve cover gasket too.
Old Jun 9, 2015 | 02:47 PM
Like they always say Charlie, "check under the hood"...
Old Jun 9, 2015 | 05:38 PM
10-4 on that one, Doug!
Old Jun 9, 2015 | 11:31 PM
Seems like you already knew, so why are you asking?
WOT
Old Jun 10, 2015 | 11:36 AM
I had to check the VIN. Yep, it's a SC2. I looked at the pictorial differences between the SC1 & SC2 and didn't see much different and I consider myself to be fairly observant...
Old Jun 10, 2015 | 03:24 PM
19bonestock88's Avatar
The main difference is the engine... The SC2 has a DOHC engine, and the SC1 has a SOHC engine... From the drivers seat, look at the gauge cluster... An SC2 cluster should have a tachometer redlining at 6500 RPM, and a speedometer going all the way up to 130mph... An SC1 will have a tach redlining at 5500 RPM, and a speedo only going up to 110mph...
Old Jun 10, 2015 | 11:04 PM
1) Saturn S-Series - Wikipedia, the free encyclopedia
2) Observe under the hood
3) Repeat step 1
Anything else added to this thread will eat up memory space that could have been used to store something more useful.
Coincidentally, I will never get back the time I spent typing this post and closing the thread.
swardSC1
Mar 7, 2013 07:30 PM
JMKV
Jan 28, 2013 02:50 PM
a-NiC
Apr 6, 2009 04:29 PM
03mustgt
Oct 12, 2007 01:38 PM
saturn_psi
Jan 16, 2006 05:39 PM
