Running Hot
Old Sep 24, 2008 | 12:50 PM
maxsat's Avatar
Shes runnin a little hot
~ Changed the ECTS and connector - fixed the high idle problem for the
most part
~ Still need to change the cam cover gasket (I have it, waiting on
saturday)
~ The car runs hot, from a few minutes after I start it till I shut it off. It
works it''s way to 1/2 between C - H (quickly) and stays there. When you
shut the car off you can tell it is running hot.
~ The 2 lights above the temp gauge come on and stay on when you start
the car for awhile 20 minutes or so, then go out. then they come on
randomly and stay on for 5-10 minutes then go out.
~ I thought maybe water pump?
~ I thought thermostat (Top radiator hose is soft, even when hot)
~ Plenty of coolant
Thoughts
~ Still looking for a service manual fpr this car
Old Sep 25, 2008 | 07:36 AM
TheEngineer's Avatar
are your fans kicking on?
Old Sep 25, 2008 | 01:35 PM
maxsat's Avatar
good question, I don''t thtink i ever noticed.. I will check tonight and report
back
Old Sep 25, 2008 | 06:13 PM
maxsat's Avatar
Good call
Drove home from work, pulled in the driveway.
Car running temp 1/2 way to hot.
Got out and checked no radiator fan running.
Turned car off... waited a few minuted, no fan kicked on.
next step?
ThanksEdited by: maxsat
Old Sep 26, 2008 | 06:43 AM
Check for a blown fuse first, then start inspecting the connections to the fan harness or a bad wire somewhere.
If this gets nothing it might be a relay
Old Sep 26, 2008 | 08:58 AM
Low Saturn's Avatar
Depending on the year of your car, the fan may not come on until the gauge gets in a higher position.
What year is the car?
Old Sep 26, 2008 | 12:06 PM
maxsat's Avatar
it is a 1998 SC2
~ I will start checking the fuses and connections.
thanks
Old Sep 26, 2008 | 12:31 PM
Low Saturn's Avatar
The fan should come on about when the gauge gets to the 3/4 mark.
Old Sep 26, 2008 | 12:49 PM
maxsat's Avatar
it typically shoots to 1/2 and stays there , unless i sit in traffic then it goes
to 3/4..
Old Sep 26, 2008 | 12:56 PM
Low Saturn's Avatar
to 3/4..
Sounds normal.
