Need a/c info
Old Mar 18, 2009 | 09:53 PM
pistonhead's Avatar
Default Need a/c info
Hi I need to install a coil .What is the air gap suppose to be on a 2002 sc1 compressor clutch.I just bought my sc1 monday.Its a fun little car.I have two more questions.Were is the backup light switch located and is there anyway to brighten up the odometer ,its bearly visable or should I be glad it even works.Every time I sell a car or boat I always give the buyer a manuel.So far nobody has given me one.Whats up with that. Thanks
Old Mar 19, 2009 | 07:53 AM
As far as a driver's Manual, or even a Service Manual for an older Saturn, I have found that eBay is always a good spot to look ...
As for the visibility of the odometer, are you referring to daytime running brightness, or nighttime conditions ???
Old Mar 19, 2009 | 09:29 PM
pistonhead's Avatar
Hi I installed the coil and the a/c works great.
I need to get a manuel.
The odometer is dim period.With the lights on it makes no difference.You cant even see it at night.Is there a backlight bulb I can replace?
Old Mar 19, 2009 | 09:51 PM
Is the dash dimmer **** turned all the way clockwise (never saw a 2002 but am assuming it was still there as in earlier years)
yes the dash bulbs can be replaced but 7 years is pretty short lifespan....I have a 95 that is only starting to lose dash bulbs
Old Mar 20, 2009 | 02:21 PM
pistonhead's Avatar
Default Dim odometer
Yes the dim **** is turned all the way up.I can see the speed and tack great.Its just the digital odometer .Day or with lights on its bearly visible.
It does still register the miles for now.Has anyone replaced the backlight in a digital odometer in a sci 2002 model. Thanks
Old Mar 20, 2009 | 09:59 PM
oops -- missed the year /digital aspect. sounds like a pain in general, as it is most likely a sealed unit -- disregard my comment about bulb replacement
ctgblue
May 31, 2011 07:11 PM
VUEinNC
Mar 22, 2008 08:05 PM
Rew W
Oct 14, 2006 01:08 PM
Dead GP
May 1, 2006 11:53 AM
tommy7133
Mar 22, 2006 04:24 PM
