my car will not start
Old Feb 7, 2006 | 01:44 AM
greggquintos's Avatar
i need help..
my car will not start. there's no fuel, i think, going to my engine. i changed the fuel pump, fuel filter, fuel injectors, i cleaned the throttle body and still it won't work. i put starter fluid and it started for about 5 seconds. WHAT's WRONG WITH MY CAR?
Old Feb 7, 2006 | 04:41 PM
ottjoe88's Avatar
check the fuses
Old Feb 7, 2006 | 09:39 PM
fuses are okay
Old Feb 8, 2006 | 02:54 PM
ottjoe88's Avatar
what year? check the grond wires. I had the same problem one time and i took the wiring harness that goes to the fuel pump out of a 1995 saturn and found that they added a ground i hooked up the ground and the car started right up
Old Feb 8, 2006 | 02:56 PM
ottjoe88's Avatar
so get the wiring harness out of a 1995-1999 saturn and hook it up
Old Feb 8, 2006 | 11:12 PM
its a 1997 sc1....i checked all the grounds... i did that first because i made a mistake taking it off the first time this happened...
Old Feb 9, 2006 | 04:49 PM
ottjoe88's Avatar
you checked the one in the trunk? if so then check the relays
jcoll72305
Jan 24, 2013 09:45 AM
blakesdad
Nov 2, 2009 06:08 AM
lowmax97
Mar 2, 2008 11:06 AM
busted240
Nov 8, 2006 01:51 AM
tonedefiant
Aug 7, 2006 09:53 AM
