How to check oil pressure 2002 SC 3 door
After 2 years just started my 2002 SC 3 door, 110K miles. There's an engine knock and before I bring this to my trusted mechanic to go over the whole car I want to be sure there is oil pressure. The oil light is not on - but I don't trust the sending unit is ok - not even sure where it is. Tried to research this but could not find specific directions for this car. Please let us all know the details, thanks!
Thanks Derf......I saw that video before I started this thread. So, I suspect you remove the sending unit and attach a pressure gauge which raises a few questions. What size and thread is needed for the pressure gauge? and should I disconnect the coil so the engine doesn't start?
To answer your questions - don't remember if there was a knock prior and no I did not change the oil before starting after 2 years. Shame on me but I had no confidence the dang thing would actually start after replacing the ECM - but it did. I only let it run for a few minutes after starting because of the knock.
