Fastening bumper emblem for ’97 SC1
Old Jun 13, 2007 | 03:01 PM
Kerry's Avatar
I received the emblem from SaturnParts but I don't know how to fasten it. It's about 2" x 3" andperhaps 1/4" thick. It has two stems protruding from theback. One, a 1/4" stub keeps the emblem aligned within the recessed enclosure on thebumper and another, a slightly tapered stem (about 1 1/4" long)protrudes from the back of the emblem, itfits loosely into a hole in the enclosure in the bumper.
The problem is that the emblemdidn't arrive with afastener; I believe it would be the kind such as used witha necktie pinor an auto-compression spring-steel nut-like fastener.I'm wanting to glue the emblembut I'mnot sure what type of glue would adhere to both the plastic backing of the emblem and the Gel-Coat paint on the bumper, perhaps some type ofepoxy? I suspect the glue would ooze into and around the stem and its hole and therefore provide the most purchase.
Suggestions?
Thanks,
Kerry
Old Jun 14, 2007 | 07:56 PM
Thats the ticket.....it's a "spring-steel nut-like fastener" or stamped steel nut, you can use a reg corse thread nut if you like. Becarefull not to over tighten.Edited by: sw2cam
Old Jun 15, 2007 | 04:25 AM
Kerry's Avatar
Hi Sw2cam,
Thanks. I'm hoping someone will recommend a brand of epoxy/glue that I can use instead of, or even with, a stamped steel nut.
Kerry
RjION
Jan 7, 2012 11:15 AM
msugoose
Sep 30, 2008 08:56 AM
jeremt18
Aug 23, 2008 01:35 PM
95_sl1
May 9, 2008 10:50 PM
97saturnsc1ca
Jan 31, 2008 05:54 PM
