engine idle adjust question
Old May 29, 2013 | 08:53 PM
john doe's Avatar
Default engine idle adjust question
my 2002 sc2 has a idle adjust screw on the throttle plate but for the life of me i cant find anything that fits it .
anybody know what size and what kind of tool it takes?
tried all my allen heads ,none fit well enough to turn it .tried my star heads too.
it did have a security nipple inside the recess but i knicked it off so my allens would fit .but still no luck .
would like to turn my idle up a tad .
Old May 30, 2013 | 07:13 AM
john doe's Avatar
morning bump
Old Jun 1, 2013 | 12:49 AM
dude
this is preset at the factory -- from what you described sounds like a security torx head. of course requriing security torx drivers. It's the fastener used when someone really doesn't want you to f with something.
That screw is only to be used as needed to attain normal idle if the throttle body is replaced.
Leave it be.
Old Jun 1, 2013 | 06:37 AM
Have you just tried cleaning the throttle body? Perhaps you're getting a vacuum leak around the intake somewhere. Maybe one of the two?
Old Jun 1, 2013 | 05:33 PM
john doe's Avatar
yeah i cleaned it twice in the last year .its finicky ,sometimes it idles good sometimes it dips down too low coming to a stop .
i guess i could replace the idle control solenoid but no code ever been thrown for it .
just a tad higher idle would do .
Old Jun 2, 2013 | 07:22 AM
Maybe your CTS is going bad. Has it ever been replaced? They seem to wreak havoc on the Saturns.
Old Jun 2, 2013 | 04:09 PM
john doe's Avatar
just threw a new code today po410......fix one thing another thing pops up..lol....seems a easy fix though .most likely a plugged up hard line going to the manifold .
or a bad air pump .
Old Jun 4, 2013 | 11:49 PM
I have owned my 94 Saturn SL2 since 1996 and never once had to adjust the idle. As far as I know it is not adjustable. If idle rpm is walking around, there is something wrong. Ruby mentioned the CTS. This thing has a high failure rate, this and dirt and crud impacting the throttle body and stuff.
Old Jun 5, 2013 | 04:18 PM
john doe's Avatar
its nothing bad , i am just picky .90 percent of the time it idles fine .its just when coming to a fast stop it dips down lower than i would like sometimes .
i just cleaned out the emissions hard line going to the head,it was carbon-ed up pretty good .hopefully that clears up the recent code .the air pump is working .
so far everythings been pretty minor and its a easy car to work on .
omega
Nov 19, 2014 01:35 PM
cloudsplitter8
Aug 24, 2012 07:47 PM
gbenderk
Apr 2, 2009 10:56 PM
drdonnbnet
Mar 22, 2009 10:11 AM
BigSmitty
Mar 14, 2008 07:23 PM
