Engine cranks almost starts but no joy
Old Dec 16, 2008 | 07:26 AM
Rodney_442's Avatar
Alrighty I will first admit to my dumb@$$ move, Sunday I changed out my ignition module and spark packs WITHOUT disconnecting the neg lead. But it started. Of course Monday when the wife had to go to work it won''t start. checked out no spark on any plug, replaced ignition module AGAIN, got spark engine almost starts. Looking at crank sensor or at a far reach timing chain. Can you help??
Old Dec 16, 2008 | 08:51 AM
Well, no comment as to the year/model, or any failure codes, so it is simply a guess that the crank sensor is failing/has failed ...
Old Dec 16, 2008 | 02:44 PM
Rodney_442's Avatar
this is a 2002 saturn SC2 3 door coupe with 135,000 miles on it
Can you see a trend here
Old Dec 17, 2008 | 09:05 AM
Rodney_442's Avatar
Thank You for your info, I went ahead and changed out the crank sensor as well. the results were the same so I decided to step on the gas, it seems as thought the engine was flooded. But for further reference the vibration my wife was feeling in the brake pedal disappeared. I believe this was due to a failing crank sensor.
Johnny lexington
Nov 16, 2012 09:17 AM
uncljohn
Jan 14, 2012 11:16 PM
stmichael4
Jun 27, 2009 07:31 AM
imp81318
Apr 25, 2008 10:24 PM
psaffel
Mar 4, 2008 08:43 PM
