compatible Guage cluster?
Old Feb 7, 2008 | 02:24 AM
92saturn's Avatar
I have a 92 sc 1.9, 5spd. The Odometer does not work. I found a guage cluster in a salvage yard the car was marked a 1992. There is a differance in them, the oil pressure guage, mine has one the other dosn't. It has a light instead. Will it still work in my car?
Old Feb 7, 2008 | 08:50 AM
Low Saturn's Avatar
No. You need a 1991 or 1992 DOHC gauge cluster. Or you can pick up a 1991-1994 SOHC or DOHC cluster and swap over just the odometers. Or you can buy the little gear that causes this problem and swap at out as well.
Old Feb 7, 2008 | 10:46 AM
92saturn's Avatar
OK, Thank You, I will swap out the Odometer. If the fuel gauge shows erratic movement(like when turning it will move about a half a tank both ways) until the fuel settles down then flutters while driving. At stop it will slow to a steady normal state. Is this the fuel pump sending unit?
Old Feb 7, 2008 | 07:14 PM
Low Saturn's Avatar
Its usually a problem with the float or sender. I'd live with it until you need to replace the pump.
Old Feb 7, 2008 | 11:57 PM
92saturn's Avatar
Ok, I will, Thanks Low Saturn for your help.
'98 Saturn SC2
Jan 24, 2012 09:59 PM
budsjlm
Jun 26, 2009 10:38 PM
phantomschic3
Jun 20, 2008 10:22 AM
undun
Nov 6, 2006 04:37 PM
50 caliber
Nov 27, 2005 04:56 AM
