Cleaning Out Gas Tank Venting System
Old Aug 17, 2016 | 12:47 AM
Default Cleaning Out Gas Tank Venting System
Hey folks,
I was wondering if anyone is familiar with clearing the gas tank venting system on an S coupe.
My gas gauge had seemingly been reading WAY LOW. I have always pumped my gas with the "handle retention" clip engaged on the max setting with no problems.
Apparently, after 253K, there is now apparently a problem. Happens at different stations, so not believed to be related to flow rate when handle retention clip is engaged on high.
If I slow pump it (control by hand) and listen to the pitch of the fuel filling, I can easily get another 3+ gallons into the car.
Anyone out there with experience? I've never had to do this on any of my other rides.
Thanks
Old Aug 17, 2016 | 11:01 AM
Sounds like a canister purge valve sticking closed or maybe time for a new canister. The charcoal may be plugged to the point that the vapors cannot pass through fast enough.
Old Aug 19, 2016 | 07:30 AM
I would think the canister purge valve sticking closed would through a handy code so I wouldn't have to think about it. I'll go after the charcoal canister first, but obviously check both while I have it on a lift to replace the last of the 4 LCAs on my Saturn and my former 95 SC2
Thank you as always, sir.
uncljohn
Jun 13, 2012 11:12 PM
uncljohn
Jan 13, 2012 07:49 AM
Matty561
Aug 3, 2011 09:20 AM
drackett
Jan 2, 2010 07:18 PM
wanderingjoe72
May 21, 2008 10:30 AM
