I have a 01 sc2 I just recently purchased. I believe I am in need of a a/c head unit? the knobs that change from cold to hot and from floor to defrost etc are really hard to turn and dont change well. any info would be greatly appreciated. Thanks Bryan |
Check that nothing is obstructing the cables.
I did :( My friend works for saturn here and he said that I needed to replace it.
do I have to pull the whole thing out then? I looked behind it and didnt find anything.
I''ll post instructions from the service manual when I get home from work.
thanks....I appreciate it alot.
Follow these instrustion from my website for removing the radio first.
http://www.differentracing.com/tech_...0-02radio.html Then remove the cables. You can see from this illustration how the controls work. You may just need a little lubrication on those gears. http://www.differentracing.com/mike/...;ntrol3gen.gif |
thankyou. That helps alot. Ill do it this weekend.
