the 94 lives!!! kinda...
Old Sep 26, 2012 | 08:24 PM
winkler91's Avatar
Exclamation the 94 lives!!! kinda...
Ok fuel pump is in and car started for first time since 2008.... It runs ... but its rough.... the cyl to the far right dies not want to fire tho.... any suggestions??
Old Sep 26, 2012 | 08:27 PM
"far right cylinder" .... the one by the right front tire ??
Old Sep 26, 2012 | 08:33 PM
winkler91's Avatar
If ur standing directly in front of car looking at motor... its the one on the drivers side... first one there
Old Sep 26, 2012 | 08:43 PM
OK -- that's cylinder #4. Could be misadjusted/worn/defective plug, bad plug wire, or bad coil pack
Old Sep 26, 2012 | 08:47 PM
winkler91's Avatar
OK... that's cylinder #4. Could be misadjusted/worn/defective plug, bad plug wire, or bad coil pack
New plugs.. new wires... coil pack still fires .... im hoping the cyl isnt shot
Old Sep 26, 2012 | 08:49 PM
Run a compression test on the cylinder, and compare it to the rest of the engine
Old Sep 26, 2012 | 09:00 PM
winkler91's Avatar
Well the problem is ... idk anyone with the tester... would it be safe to drive about 5-10 miles to advanced auto?
Old Sep 26, 2012 | 11:32 PM
you are asking a question about the probability of something making more damage on a car taht has not run in 5 years, that I have not seen, have no idea what the basic condition is and I can neither hear, feel it or touch it and I actually have the tools to test those things with out gambling that if i drive it 10 miles I might lunch something expensive or unfixable.
Sorry, not my call. I can't help you.
Old Sep 27, 2012 | 07:49 AM
Get some Marvel Mystery Oil and fill that cylinder with it and let it sit for a couple of days. With the spark plug out, crank it over to clear the cylinder and then check your plug for fire. If you've got fire, install the plug and start it up and drive it. Just for s*&ts and giggles. Maybe it's got stuck rings on the piston and no compression as previously mentioned. If that's the case, then the Marvel may free them up.
Old Sep 27, 2012 | 08:09 AM
WRT to the compression tester -- you can usually rent one at AutoZone .......
