I was not able to upload pictures with my iPad, however the Macbook Pro worked fine. I only use a PC if I have to. |
thank you , I had already tried that a few times , but I tried again just in case all I got was an Err 1 , tried 2 more times till it now says LOCK , I will get the LOCK off tomorrow by leaving the key on ACC for an hour so it will go back to _ _ _ _. there must be an issue with the code , the 4 digit code I get when I push the 1&2 buttons is 5555 . when I call in to the 800 number they issue me another code based on that number ,
Do you need the factory method on how to get the correct code? |
yes I will try that , thank you
Went out this morning to do the ACC key and wait the hour to remove the L O C K from the radio , and decided to start from the beginning by removing the battery cables , Waited 30 min due to racking leaves before reconnecting and BAM the radio was unlocked and playing no longer showing _ _ _ _ . Strange …. Thank you to everyone who helped ..
Terribly unlikely but as long as it works.
You're welcome. |
back in the saddle
https://cimg0.ibsrv.net/gimg/www.sat...60b9c823c9.jpg |
Awesome! Never said I didn't believe you.
I've seen much stranger.... |
800 number?
Is there a 800 number in working order still?
Any GM dealer should be able to help you to contact the right people.
