2001 saturn sc2 1.9l
clutch seems ok but when i shut the car off it acts like it does not want to shut off like it wants to keep running wandering if a p0405 code could make the vehicle act like this or could it be the clutch making it shutter a little and not wanting to shut off when you turn the engine off with the key wish i had a solus gm code reader to find out more seems like it shifts great PLEASE GIVE SOME ADVICE looks like the spark plug wiring is old but still getting good spark should i take the plugs out and replace with new
Old Yesterday, 06:33 AM
OceanArcher's Avatar OceanArcher OceanArcher is online now Super Moderator Join Date: Jul 2008 Location: Riveria of America Posts: 2,641 Default -------------------------------------------------------------------------------- Hi Jason -- How many miles on your Sc2 ?? A failure in the EGR circuitry should not make your car run-on (diesel) as you describe. There are other problems at work here ... __________________ Mike -- MS Gulf Coast '93 SW2 -- dark blue '02 L200 -- gold '09 Aura XE -- burnished gold Ocean when I moved this thread posts your post did not move with it. That's why it looks as it does. |
110K thanx for replying what should i check for then if it is not in the egr system
:):cool:
Originally Posted by jasonelliott
(Post 39677)
