2000 Saturn sc1
Old Apr 28, 2019 | 01:17 PM
Hondacb7501972's Avatar
Default 2000 Saturn sc1
I have a 2000 sc1 3 door. I have alot of water on the floor. I have a sun roof that is not in use. What is wrong and how do I fix this.
Old Apr 29, 2019 | 12:49 AM
Sunroof drain lines at each corner. One or more is clogged.
Please search the site for sunroof drain clogged, blocked etc. If I remember correctly, someone actually posted a picture of exactly where they are and where they run
Old Apr 29, 2019 | 08:41 AM
I agree with derf 100% about the clogged drain tubes. If you have an air compressor and blow gun for it, I'd recommend you try blowing them out with about 100psi. If yours goes higher than mine, then use a higher pressure.
Nobel Hansen
Jul 25, 2019 08:07 PM
stephen cupp
Nov 21, 2015 07:01 PM
webbj8150
Jun 22, 2015 09:02 PM
SL2 driver
Feb 25, 2009 09:29 AM
deborahallyson
Feb 8, 2009 12:54 PM
