Good info to have
Old Feb 17, 2018 | 12:48 AM
Jamison Chainz Stewart's Avatar
Default Good info to have
just FYI for anyone that needs it if you put a automatic wiring harnes and automatic computer in a 5speed it will have no revlimitter it will turn up until it's just floating the valves
Old Feb 17, 2018 | 04:22 AM
Remarkable!
You have 24 hours from the time stamp on this post to
---post the technical reason why this happens
---post a pic of your SC2 dash @8000 rpm with your shifter in view in the bottom right hand corner
(just so we know you're for real on this)
Old Feb 17, 2018 | 09:47 AM
It's for real I don't have it done In my car ATM my buddy races circle track with a 01sc2 and that's what he has done for more Rpms you have to hook the shifter modual up and put it in second gear and it works idk why but it dose and also Buick lasaber injectors will fit in a Saturn and the dump 2xs as much file as a stock injector I will get pics and videos of everything when I see hi. Next
Old Feb 18, 2018 | 06:02 PM
19bonestock88's Avatar
I read about the auto PCM swap on an S series... it does indeed get rid of the limiter because RPM is limited by what gear the trans is in (it should shift before redline), thus I’d you do this on a manual car you can exceed the normal redline
Old Feb 19, 2018 | 02:02 AM
So then the rev limiting safety features for when the car is below 3 mph and is in neutral are......
----still there because there is an additional criterion involved (vehicle speed >= 3mph) and it's handled by different code in the PCM
---gone because neutral of a 5 spd is not understood by an Auto PCM as anything special (not interpreted as the N of an Auto)?
Chainz: Please note that I never said you were wrong--I only asked you to back up what you posted.
I've been driving S cars since 92 and I have never known of this.
Thank you for the addition of knowledge to our forum.
Bones -- I can't believe you hide stuff like this from me after all these years.......
Old Feb 19, 2018 | 02:21 PM
Yes but if you click the automatic trans gear switcher to2nd gear and hook it up to a manual it will not have a rev limiter we learned this from testing it in my buddy s series dirt track car and yes sorry for taking it the wrong way didn't mean anything disrespectful
Old Feb 19, 2018 | 03:50 PM
nor did I.
We occasionally get bozos on here posting sheet and as mod, I call them on it.
No harm no foul.
Peace
Derf
Old Feb 20, 2018 | 05:20 PM
I read the auto PCM thing over on 6S, but I also experienced the second gear hold... if you shift an automatic S car into second, it locks out every other gear including first... I guess you could also then exceed the redline.. I used it on my ex’s S car (single cam, auto) to force an early WOT upshift into second at 5k RPM instead of 5500... second gear landed nearer to its torque peak and it shaved 0.1sec off the 0-60 time...
98 SL
Apr 25, 2017 12:39 AM
VUEinNC
Mar 22, 2008 08:05 PM
Rew W
Oct 14, 2006 01:08 PM
Dead GP
May 1, 2006 11:53 AM
tommy7133
Mar 22, 2006 04:24 PM
