classic projects
Old Oct 23, 2024 | 02:05 AM
  #31
lanxer57's Avatar
I removed all of the bearing caps, except the main bearings in the front and back. The main bearings that I pulled seem fine, the cylinder walls seem fine, the cam lobes look a little pitted around the edges, most of the rod bearings are a little pitted, except cylinder one, which has deep groves, and cylinder seven, which had spun, the tangs were gone, and its journal in the crank shaft had lost as much as 1/16 in compared to cylinder 8 next to it.
Old Oct 23, 2024 | 08:31 AM
  #32
IMHO, if it were mine, I'd pull the engine and do a complete overhaul with a new crank, rods and bearings just to make sure. Have the cylinder walls honed after having the block dipped too. That will help to break in the new rings you'll put on the OEM pistons.
Old Oct 23, 2024 | 01:38 PM
  #33
lanxer57's Avatar
With the vehicle now in our steep driveway, pulling the engine would be too dangerous, and with the money running out (as usual), only what is absolutely necessary may be replaced, especially that the saturn needs control arms before the sway bar pulls out of its bushings...
Old Oct 24, 2024 | 08:01 AM
  #34
Sounds like it's time to put the Caddy project on hold and take care of the Saturn.
02 LW300
Dec 7, 2021 06:31 AM
02 LW300
Jun 12, 2020 08:13 AM
rjp869
Nov 27, 2018 07:22 AM
wavehog
Nov 29, 2014 08:16 AM
RjION
Jun 7, 2014 02:49 PM
