2008 Saturn Aura
Old Nov 18, 2018 | 08:01 AM
tamyreaves@yahoo.com's Avatar
Default 2008 Saturn Aura
Just bought this car. Drove it earlier today started right up. Now it wont turn over. Its dead. Any ideas?
Old Nov 18, 2018 | 10:26 AM
19bonestock88's Avatar
First up, check battery... then check all the ground and power cables... then check the starter
Old Nov 18, 2018 | 05:53 PM
Does not turn over = not cranking rotating the engine?
some folks use different terminology.
Do the interior lights come on at all?
Might you have left a light on(glovebox, door ajar)?
Most likely cause is either the battery, corrosion or looseness between the battery terminals and the battery cables, or a poor/ corroded ground to the body from the negative battery cables.
Battery at rest should be approx 12.6 DC V.
Do you hear anything at all when turning the key to "crank" position?
Additionally, after doing the above, you may wish to check the fuse for the starter which is either in the underhood junction box or in the instrument panel junction box. The cover of each has the respective fuse layouts on the inside of the cover
02 LW300
Feb 3, 2019 12:03 PM
BakerSC2
Jan 9, 2019 11:14 PM
SC1-4Banger
Aug 3, 2015 05:17 PM
mandee_07
Oct 30, 2014 10:22 PM
uncljohn
Sep 9, 2010 06:07 PM
