-   Nitrous, Super Chargers, & Turbos (https://www.saturnforum.com/forum/nitrous-super-chargers-turbos-18/)
-   -   Nos (https://www.saturnforum.com/forum/nitrous-super-chargers-turbos-18/nos-3452/)
Vorlon Jul 4, 2009 11:36 PM
Nos
Hey I'm interested in some cheap go fastness, whats teh best amount bottle size to use? Its a twin cam SW2 94.
Thanks
Dane
derf Jul 5, 2009 11:00 AM
Not recommended with stock internals.
I do believe a 50 shot is enough to put a hole in the block on a stock S car engine (think I saw the video evidence on you tube)
Consider yourself duly warned
Vorlon Jul 5, 2009 05:18 PM
What else du I need to add? exhaust, intake and header?
derf Jul 6, 2009 07:05 AM
You'll find it difficult to get much HP improvement out of these S car engines, between lack of mainstream support and the lack of mainstream support.
Exhaust will of course increase flow through the system......CAI might add a few HP but not noticeable.
If you want some speed, turbo it. But again, there is very little mainstream support. You need to piece the system together -- although it has been done by quite a few (see differentracing.com) and there are a few guys out there building custom manifolds and intakes.....
but it's not cheap.....
freeride og Jul 16, 2009 08:23 AM
Nos
Befor you even consider Nos you have to have and engine that can handle that much power. You would need to build an entire engine up top and bottom end. Exaust and air intakes are the least of youre concerns. Checkout this site for tones of Saturn parts: www.importperformanceparts.net
RjION Jul 16, 2009 04:03 PM
75 shot or less if your engine is in good shape. I have a number of friends running 50 and 75 shot on S-Cars. If your engine has over 90K your just going to turn it into a boat anchor using more then a 25-30 shot.
