replaced every part I can think of
Old May 16, 2007 | 10:24 PM
redsaturn97sc2's Avatar
I have a 97 Saturn SC2 DOHC with a manual transmission. I have a problem with when you depress the clutch to the floor while shifting or just shifting into a neutral to come to a stop, the car will die. I have replaced the EGR Valve, Crank sensor, IAC Valve, TPS Sensor, PCM, Electronic Coolant Temperature Sensor, O2 Sensor, MAP sensor and the coil packs and the ignition control module. I am about to pull my hair out. If anybody can help, please help!!!!
Old May 17, 2007 | 01:29 AM
GarrenNatas's Avatar
Try replacing the engine... lol
Have you tested your alternator? And could it be something's tweaked with your clutch safety switch? I don't know how but it's an odd possibility. Throttle cable?
I don't know... But it just sounds as if your idle is dropping extremely low whenever your RPMs drop quikly and it chokes itself out...
Old May 17, 2007 | 02:29 AM
ducky's Avatar
Is your normal idlearound 800 rpm? If not then have you may have to examine the coolant sensor/connector, the replacement sensor must be brass and the connector must be free of corrosion otherwise it will not have good electrical conductivity. If replacing the two-wire connector buy the replacement from the dealer ($30) or take it from a junk yard connector off the air temperature sensor. The other possibilities are poor connections, dirty throttle body/linkages, and maybe an intake gasket leak that may be found by spraying carb cleaner around the the intake manifold with the engine running. Any change of rpm would indicate a vacuum leak and the source taken care of.
Old May 19, 2007 | 09:20 AM
He said he already replaced the ECTS but the connector is still a good idea... As for the vacuum leak: wouldn't that make it so the idle would be too high and not die on him? It seems like a vacuum leak is what he needs right now. A throttle body cleaning definitely sounds like it should help... And how's your intake? Is the filter dirty or could it be clogged somewhere?
Old May 19, 2007 | 09:21 AM
btw: Any problem you fix with your car, please update the forum... I have the same exact car that you do (mine is red, too) and it's having some issues as well.
goaliemo
Aug 2, 2015 12:22 AM
ericgray1970
Jan 16, 2014 04:25 PM
paulruiter
Oct 20, 2010 08:35 AM
vettesherps
Jun 21, 2010 07:32 PM
sgm81
Dec 21, 2006 09:48 PM
