New gal....maybe
Hi all,
I am here because I have been offered a 95 Saturn. At this point all I know is that it is a 4 door sedan. I am leaning towards accepting it but I was hoping that I could find out about any 'quirks' it might have. Are there any common issues I should be aware of. I was told it drove quite well and is getting 35 mpg on the freeway. I am going to look at it tomorrow and perhaps test drive it. Thanks in advance for any tips or comments. |
Spend a few bucks, and get a CARFAX pulled on the car. If you buy it, change the oil and filter first thing. A little "loving care" is all a Saturn needs to have a long and trouble-free service life
Oh, and welcome to the Forum |
A question on issues.
I have been given the choice between the Saturn or a Toyata Tercel (80s model) 4x4 which is also a attractive option even though it is older as I am a skier. I am much more familiar with the Tercel but the Saturn gets better milage and is a good 10 years newer so I am torn.
make sure it idles smoothly and below 900 rpm
let it sit and warm up until the auxiliary fan kicks in to cool down the engine (do this with the hood up) find out from the owner how much oil the car burns (if they say none they are most likely lying). Get it up to highway speed and make sure it drives well without shimmys and shakes Take it to your local mechanic for a once over. And please no double posting |
(Post 25643)
I am not completly in agreement with Derf on the oil burning. Mine doesn't but than again the recommended light weight oil which has lead to the problematic oil consumption as a function of time and distant was never used. When I bought mine I immediatly started using an oil more compatible to temperature ranges the car was driven in and it never has used a drop. BUT, if the owner has followed factory recommended oil change intervals and the (stupidly) recommended light weight oil the odds are it burns some. My self, I have no use for an older heavier 4 wheel drive vehicle so I am biased. However something that is equally important or maybe more so. Toyota is still in business. Saturn isn't.
That says something for ease of obtaining parts and service. My preference, the Saturn. But then again, you might not be building a Mercury Marine engined obscure station wagon for the purpose of Street Racing a sleeper. So! So much for my opinion. |
Unc -- I said most likely lying...your 10W-40 rants are quite memorable
Well I checked the oil today and it was really black but on the full mark. He had just driven the car from Texas to Wa state so I will be changing the oil very very soon. I also plan on doing the normal stuff...new air filter, new plugs and wires, new fuel filter (where is that little bugger, I couldn't find it in the engine bay when I looked) and probably a new thermistat too. I suppose a radiator flush and coolant change might be in order as well. I like to start off knowing these things are good on any used car I buy.
Originally Posted by atlast
(Post 25685)
, new fuel filter (where is that little bugger, I couldn't find it in the engine bay when I looked) .
On the choice of cars - 4x4s can get stuck too, Age plays a large roll also. |
