-   -   Howdy (https://www.saturnforum.com/forum/new-member-area-9/howdy-7216/)
86isuzu Nov 10, 2012 07:14 AM
Howdy
Hi, I'm Mike from WNY, just bought an 01 SL2 5speed with 85k on it yesterday. Looking to squeeze as much gas out of it as I can. :)
Rubehayseed Nov 10, 2012 08:15 AM
Welcome to the forum, Mike. Just take it easy on the gas pedal and try to keep it in as high a gear as you can for your best economy.
derf Nov 10, 2012 08:49 AM
yo...
SilverCoupe#SC2 Nov 10, 2012 09:16 AM
Welcome to the forum mike
OceanArcher Nov 10, 2012 11:46 AM
Yes indeed - Welcome to the Forum. Also make sure your tires are properly inflated
sw2cam Nov 10, 2012 02:48 PM
You do the same with this car as you would with any car, but when replacing plugs use SATURN or NGK replacement plugs nothing other. When the ETCS needs replacing, use the one you get from the DEALER no other. Replace the ETCS connector at the same time.
Welcome to the forum.
trike1946 Nov 10, 2012 07:11 PM
Welcome to the Saturn Forum.
uncljohn Nov 11, 2012 01:24 AM
Yup, welcome. 85K is not a bad mileage. Don't worry about squeezing gas on it, change the oil using something at a minimum of 10W30 and if the engine has not started using oil yet it should keep it from it.
RjION Nov 13, 2012 08:26 AM
Hello and wecome to the Saturn Forum
