200o saturn sl1 secondary air injection
Old Mar 4, 2007 | 05:13 PM
jennievias's Avatar
ok i have a 2000 saturn sl1 and one day i was driving and it began to over heat! the next day it started right up and i drove it to work after work it wouldn't start.
i hooked my car up to a diagnostic system and it says i have a secondary air injection malfunction code p0410
and also and 02 sencor circut high voltage! bank 1 sencor 2 code p0138......
i have read the haynes repair manual and it doesnt help! can anyone help! thank you jenn
Old Mar 4, 2007 | 11:20 PM
P0410 Secondary air injection malfunction
No personal experience with this one, but, based on a quick web search, if the air pump is operational, I'd start by replacing the Engine Coolant Temp Sensor (ECTS) and connector (Saturn only part).
A bad ECTS will usually cause the PCM to think the coolant temp is at -40. This causes the PCM to compensate by making the air fuel mix way too rich.
The sufficiently rich mix is probably what is triggering the P0138, which, as it turns out, is triggered by the rear 02 sensor putting out a consistently "too rich" signal......
Try ECTS swap first, clear codes, and see if the P0138 returns. Hopefully it will not.
Keep us posted
Derf
daved
Jul 28, 2010 02:57 PM
pmk
Jun 22, 2009 10:21 PM
alex_0227
Mar 19, 2009 11:54 AM
Abosherpa
Jul 19, 2008 09:06 PM
whampam7
Jun 21, 2008 08:43 AM
