1999 Saturn wagon license plate lights
Old Jan 5, 2020 | 02:02 PM
clement.j.joyal@gmail.com's Avatar
Default 1999 Saturn wagon license plate lights
I am stumped on this issue. My license plate lights dont work and Im not sure why. I downloaded schematic of lift gate and checked for power at the harnesses. there doesnt appear to be power. That said the buzzer and other lights on same circuit work fine. I am perplexed as I dont know where else to look for the problem. It would appear that it is an obvious open in circuit but connections appear okay from the liftgate back to the harness above ceiling in back cargo area.
Old Jan 5, 2020 | 10:19 PM
I have had problems where the wires bend when the hatch or trunk lid opens and closes. Police cars are the worst, they open and close the trunk a minimum of 6 times a day. The problems are the wires themselves.
Old Jan 5, 2020 | 11:35 PM
If the fuse is not blown, it sounds like you lost the ground or both hot and ground
Check resistance between the ground in the bulb socket and a known good ground. If it is more than 1 ohm, you've lost the ground.check voltage between the 12v side of the socket to a known good ground. You may actually see 12v.
Winfield
Jul 25, 2019 02:13 PM
BakerSC2
Jan 9, 2019 11:14 PM
dcarr
Sep 27, 2016 01:58 AM
mandee_07
May 5, 2015 02:04 PM
TxFireman1972
Feb 17, 2011 08:38 PM
