-   Headers, Intake, & Exhaust (https://www.saturnforum.com/forum/headers-intake-exhaust-17/)
-   -   Getting in tune (https://www.saturnforum.com/forum/headers-intake-exhaust-17/getting-tune-11457/)
Ionscott Sep 6, 2018 11:49 PM
Getting in tune
So if I change my intake I need to have a shop tune it?
19bonestock88 Sep 7, 2018 12:03 AM
It depends largely on what car you have, and what kind of intake you’re installing...
A DIY short ram or the like on a car that doesn’t use a MAF sensor will likely be fine unless you don’t relocate the IAT sensor...
On a car that uses a MAF, extra care has to be taken to make sure the MAF is located in smooth airflow and if you changed the sampling tube (that the MAF bolts into) itself, be sure to keep the tube size the same, or it will throw off the readings and result in a lean(P0171) or rich (P0172) code, or some other drive ability issue... generally in cases like these it’s best to get a tune if you can...
the issue is that hat a lot of Saturns have NO aftermarket tuning support...
only models that im aware of that can be tuned are:
00-03 L series 2.2
06-07 Ion 2.4
07 Ion 2.2
07-up Aura 2.4, 3.5, and 3.6
Ionscott Sep 7, 2018 12:32 AM
Getting in tune
I have a 2004 ion redline. Thinking of the warrior z secret weapon.
19bonestock88 Sep 7, 2018 12:46 AM
Honestly I’d go with the ZZP intake for the Redline if you can find one/can swing it... I have one on my RL(that I’ve been trying on and off to part out) it sounds great and it’s pretty well made... and definitely get tuned after doing an intake on the LSJ, the tune itself can add 10-15whp...
Ionscott Sep 7, 2018 01:39 AM
Getting in tune
Your parting out your Saturn. If so and have an intake for sale how much
19bonestock88 Sep 7, 2018 02:15 AM
Sent you a PM
derf Sep 7, 2018 03:49 AM
beat me to hooking you two up......
19bonestock88 Sep 14, 2018 12:02 AM
Guess he never stuck around to buy anything or receive more advice...
derf Sep 14, 2018 12:12 PM
Can't believe he'd run away from a full parts car minus running engine
19bonestock88 Sep 15, 2018 09:21 AM
I think I’d have better luck fixing the car and selling it whole, rather than selling the performance upgrades...
