Won’t Start
Old Oct 26, 2005 | 09:27 PM
SQUIGR's Avatar
When i turn the key nothing happens, no clicking no nothing. And when i open my door the dome light does not turn on, and the passenger door will not unlock with the keyless entry, and the rear defog will not turn on. HELP MEEEEEEEEEEEEEEE!!!!!!
Old Oct 26, 2005 | 09:30 PM
Dead battery / loose battery terminal connection......
Old Oct 26, 2005 | 09:42 PM
SQUIGR's Avatar
no ,everything is connected tightly. The battery is brand new and the starter is brand new.
Old Oct 26, 2005 | 09:51 PM
How "brand new"?
Did this problem start after the battery and starter was replaced?
Lack of interior lights indicates very weak battery -- does ANYTHING (accessory-wise) work?
Get someone to jump your battery with a good one.
New battery may be a dud. Has it ever started the car successfully?
Was it hard to start (if it did)?
Old Nov 1, 2005 | 05:02 PM
ottjoe88's Avatar
may have a bad alternator
Old Nov 1, 2005 | 07:18 PM
SQUIGR's Avatar
sorry guys the problem was none of the above. It turns out that the ground wire for the starter relay, that they located under the driver seat was bad. And the dome light works, but the pin switch for the door is no good. The switch for the rear defog/defrost has gone bad also. But i got a new one. Thanks for all your input guys.
Old Nov 2, 2005 | 06:09 PM
Patrick's Avatar
Administrator
well, glad that it worked out for you!
playa0069u
Engine & Internal
Feb 26, 2009 08:26 PM
imaukfan
Jan 19, 2009 10:19 PM
soxman
Apr 12, 2008 03:13 PM
redcannon
Jun 10, 2007 04:11 PM
elnino
Jun 5, 2007 09:01 PM
