Windshield Removal
Old Oct 22, 2011 | 02:22 PM
Default Windshield Removal
Hey, have any of you guys ever removed and replaced the windshield on your car? Last week when I was at Pull-A-Part in Nashville, two of the SC coupes had perfect windshields. I could use another one for mine, but I have not removed a windshield since back in the 70's and don't have a clue as to how this sum beech comes out. I removed the wiper arms and lower trim pieces but can't see where to go from there. Oh, I do know there are two 7mm bolts at the bottom of the windshield. There is one on each side. I just can't see if there are any other bolts or trim pieces that need to be removed. If anyone can help, I'd sure appreciate it.
Old Oct 22, 2011 | 06:00 PM
only ever had mine professionally replaced; been told that, due to the extreme curvature on the sides, they are actually quite difficult to do
Old Oct 22, 2011 | 09:46 PM
Well, I may try to remove one at the junk yard the next time I go. If I break it, no big deal. They'll never know. I can't afford the three hundred bucks it would cost for one to be installed around here. YIKES! I only gave eight hundred for the car.
Old Oct 23, 2011 | 07:53 AM
hoseppi's Avatar
Piano wire does the trick. The newer( 96SL and 97 SC) are easier, but the older ones are still doable.
Old Oct 23, 2011 | 09:56 PM
I had a guy tell me he uses a guitar string. I'm guessing it's not quite as strong as a piano wire. I just wonder how the hell you'd get it started.
Old Oct 24, 2011 | 09:42 AM
hoseppi's Avatar
Piano wire...guitar string, it's all the same. I know the piano wire comes in 25' rolls, and sometimes you need a 5-6 foot piece. I don't think guitar strings come that long. To start, just push the end of the wire through the butyl seal with a needle nose pliers. Then hook up your 2 vice grips and start sawing away. Be careful around the headliner as the piano wire can't tell the difference.
Old Oct 24, 2011 | 02:47 PM
I'm not sure that's something I'm going to attempt, Howie. Even though I can get a windshield for about fifty bucks at Pull-A-Part, I'd still have to pay someone to install it in my car and I don't know how much that would run me. I'm in no hurry anyway since none of the chips are in the line of vision. Yet!
95jive
Jul 18, 2008 08:46 PM
ThaBean
May 14, 2008 08:29 PM
illiano
Sep 16, 2007 07:47 PM
hartman
Mar 22, 2007 02:10 AM
toyo7
Mar 3, 2007 08:28 PM
