-   -   valve seals 1.9 DOC (https://www.saturnforum.com/forum/general-tech-help-13/valve-seals-1-9-doc-5644/)
thx569 Apr 15, 2011 08:38 AM
valve seals 1.9 DOC
Has anyone replaced valve seals on an SL1 1.9 DOC engine ? Any help appreciated as to what's involved. Engine is using oil and I'm assuming that's what the problem is.
P
OceanArcher Apr 15, 2011 11:16 AM
Actually, if you have an SL1 vehicle, then you have a SOHC engine not a DOHC.
Go to your local library, and get the shop manual for your year Saturn. It will show you the answers to your question step-by-step ... or you could go to the local Autozone (or similar store) and buy the manual. They really have a great deal of information about your car, even if you don't personally turn the bolts ........
Also - please don't multiple post the same question
derf Apr 15, 2011 10:17 PM
oil control rings and valve guide seals are more likely your culprits
thx569 Apr 19, 2011 06:15 PM
It is so a 1.9 sohc - not what I said before
Thanx for that response. It's a bit more helpful than that other guy. Are there any "look out for"s that I need to be concerned about? After doing a search, I think this is a fairly straight forward job that I'll try before a teardown.
And no, I will not do the silly thing and buy a Haynes book of trash.
