valve seals 1.9 DOC
Old Apr 15, 2011 | 08:38 AM
thx569's Avatar
Default valve seals 1.9 DOC
Has anyone replaced valve seals on an SL1 1.9 DOC engine ? Any help appreciated as to what's involved. Engine is using oil and I'm assuming that's what the problem is.
P
Old Apr 15, 2011 | 11:16 AM
Actually, if you have an SL1 vehicle, then you have a SOHC engine not a DOHC.
Go to your local library, and get the shop manual for your year Saturn. It will show you the answers to your question step-by-step ... or you could go to the local Autozone (or similar store) and buy the manual. They really have a great deal of information about your car, even if you don't personally turn the bolts ........
Also - please don't multiple post the same question
Old Apr 15, 2011 | 10:17 PM
oil control rings and valve guide seals are more likely your culprits
Old Apr 19, 2011 | 06:15 PM
thx569's Avatar
Default It is so a 1.9 sohc - not what I said before
Thanx for that response. It's a bit more helpful than that other guy. Are there any "look out for"s that I need to be concerned about? After doing a search, I think this is a fairly straight forward job that I'll try before a teardown.
And no, I will not do the silly thing and buy a Haynes book of trash.
meaninglessvanity
May 6, 2009 09:40 AM
mjdjlh2000
Mar 23, 2006 01:26 PM
strick
Jan 14, 2006 08:29 AM
gohsthb
Oct 12, 2005 04:08 AM
