transmission
Old May 12, 2018 | 07:26 AM
root's Avatar
Default transmission
I have a 2000 sl1 that i have replaced valve body in trans about 50,000 miles ago now it has started to shift hard again and now has a high pitch whine as u accerlate but shifting has then switched to more of a slipish slow shift. Any help appreciated
Old May 13, 2018 | 09:15 AM
Fluid full? How many miles since lat tranny fluid flush? Let's look at the easy stuff first.
Old May 15, 2018 | 06:20 PM
You sure you have the gaskets sealed and is the dip stick pushed in all the way?
Old May 16, 2018 | 10:12 AM
Updates?
Old May 20, 2018 | 06:04 PM
root's Avatar
Yes changed fluid and filter .Still has whiney noise and shifts hard
Old May 20, 2018 | 08:48 PM
Does the whine change with the throttle? Does the whine go away in park and neutral? Can you change the whine with the throttle in drive with your foot on the brake? There may be crap in the governor or the throttle pressure system might be sticking.
feather618
Apr 4, 2020 07:22 PM
Bobbed06
Oct 31, 2012 09:09 AM
